Originally Posted by pungo
The LED rind is held in by machining a groove in the stock AE assembly. Unfortunately, the lights would require being sent back for removal of the AE LED ring. The LED would block allot of the light from the stock bulb so the ring would get removed.
Pungo, Were you able to remove the AE rings from the headlights in order to machine them?
