Originally Posted by crfine88
They are rivetted on. You can just pull them off or trim them out with a utility knife from the inside of the fender well. You don't want to do this from the front of the car through the ducts. You want to remove the front wheels and pull them off toward the cockpit.
whoa, just had a gander down my front brake ducts, and there are indeed flaps of plastic covering what i can tell is more than 50% of the outlet! 4 rivets, 2 on each side, not going to be a particularly clean pull. hmm.
