Originally Posted by Jax543210
So you pry that panel off from the trunk area side rather than from the driver seat side?
Wish I knew what the panel looked like underneath so I could pull on the right spots.
Yes, carefully. The front has a section that is like a tongue-and-groove and locks under the lower portion above the cubby door. There are 4 metal clip things that are attached to fragile plastic, those look like they will break easily. Your pic looks like a misalignment, so you may want to life from the front and rear simultaneously and carefully, it feels like it won't budge, but it will.
#16 in this pic doesn't really detail the underneath and the clips, but #17 is what the clip looks like.
