Originally Posted by Lucky1
My indy told me to wait until I hear the valves ticking before getting them adjusted. Are there real risks to doing that or should I be getting the adjustment done proactively dead on the 30,000 mile mark? Also any idea what this job would cost at the stealership?
that's terrible advice, sounds like its time for you to find a new indy.
the point of the service isn't just to make your engine quieter, there's a bunch of other stuff you should check at the same time.
most indy shops will charge between $500-$700 for a valve adjustment including the new seals, gaskets, etc. I've seen dealers quote anywhere from $1700 to $2500 for the same job.
