      12-05-2012, 04:59 PM   #15
tikamak
Lebanon
58
Originally Posted by Beedub View Post
have you seen the AFRs ??? not much room for error at all. what exactly are evolve doing to extract so much power from these kits.....
What salman does exactly is adjust the timing and ignition of the engine to increase the dynamic compression inside the cylinder. What happens exactly is that he reduces the time where both intake and exhaust are open at the same time and the air is hovering by over the cylinder to a minimum. This produces more power as well as let's the engine breathe better and be efficient without getting into the knock limits.
He also uses better methods that are optimized as well as some other stuff he refused to share with me, but I do trust his tuning especially after I have discussed his methods with him and I have seen how my car behaves with his tune.
It's just that much better to drive, you can feel the engine behaving at its best.
