Originally Posted by Kgolf31
I don't know where you live so take this with a grain of salt.
I personally run Michelin IceXi3 Tires on my 128i...the Z4M gets stored for winter.
However, these are a full blown winter tire that is a very soft compound. If you see frequent temperatures above 45 and/or mostly rain/some minor snow these "might" be overkill.
In that case, I'd go more a performance snow oriented route.
PS - You might be seeing limited options because of the tire size.
Grain of salt taken
The Z4M is now my DD, but since I work predominantly from home, my commute is not that bad.
I live in NoVA just outside Washington, D.C. Our winter's don't generally start until late December and run through early March. So that's my planned winter interval.
Our Winters are generally mild with some periods of snow up to 8". Sometimes we get hammered. Given that, I think the Michelin IceXi3 would be overkill. As you and other's have mentioned, tire selection for the OE wheels is going to be the problem.
John
