The backs might rub a little on the outer liner if you go very low but wouldn't require much to gain the needed clearance. I run a 10" et 22 in the rear of mine with a 265 tire and can tuck the wheel and tire without issue. up front you'll be fine, that's not aggressive at all. I run a 9.5" et 26 up front with a 265 and have a little rubbing on the liner at the leading edge after a mild fender roll and with camber in the mid -2 range currently.
I'd run your original 10" et 20 out back and change the front to the et 26,maybe even go to a 9" at that offset if you have the option.
