      11-05-2011, 08:17 AM   #17
Neverlift328
Drives: 2007 Z4 M Coupe
Originally Posted by Roffle Waffle View Post
what offsets do you want to run on 18x9?
I wanted to run 18x 9.5" offset 35 265 all around probably Hankook RS3
I will install camber plates to get around 2.5-3 degrees of negative camber 5 mm spacer most likely but not 100%
"The best way of making a car faster is to tighten the nut behind the wheel"
