      12-03-2017, 05:55 PM   #27
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Originally Posted by wdb View Post
Salty you need to change your avatar to a butt sticking out from under the hood!
Great info. I'm planning on doing the VANOS thing over the 'quiet time' this winter. Thanks for pulling so much information together in one place.
I was traumatized as a teenager when I dropped a valve cover bolt down into an engine while trying to change a valve cover gasket and swore off working on engines. 35 years later, I'm finally getting over it.
Salty
wdb4758.00
