Originally Posted by Eau_Rouge111
Hey guys...before we left for that quick spin on a Saturday...we were chatting about brakes given how I picked up a set of front M4 calipers. Well, from the thread below (I know is an e46 M3 but would I be wrong in assuming they are very similar to the Z4M?)...it does not look like too hard a job as that bracket I can build quite easily around here at my shop...ordered a set of rear M4 calipers from the same crashed car I picked up the fronts from...so plan is to do a lot more research and if possible...this winter the plan is to get it done...should be a fun little project if I can pull it off.
Cheers.
http://www.m3forum.net/m3forum/showthread.php?t=558795
E46 m3 zcp/csl use the same brakes as the z4m so brakets should be identical. I'd reach out to the guy that made them already and ask if he can provide the cad drawings. Might be a long shot but doesn't hurt to ask.
Also if you want some expert advice on brake bias etc ask
The HACK as he seem to be very knowledgeable in that area.
