OK, I'm doing some of this same research. I have the same rims (ZCP). The issue is that I need to run PSS's (I'm sold on those!), and they do NOT have a 285/30. I currently have Hankook 285/30 and 245/35's. Really like the look, but the Hankook's need to go. My options in PSS are:
1) as stated above, go with a 275/30 in the back and the same 245/35 in the front. Problem is, the rear tire height is now lower than the front. perhaps not enough to notice.
2) go a little taller, and stay with a 285/35 in the back, and a 245/40 in front. May cause rub issues if I lower? anyone done this combo?
3) go to 275/30 in back, but use a 235/35 in front. That way the front and rear tire height is a closer match.
Anyone running any of these combos? appreciate any feedback...
