when i did my relocate of the pump i did it with the top on i had a small inspection camera and poked it down the hole and saw a tie strap holding the pump housing to the top frame i sharpened the end of a 1/4 inch steel rod about 12" long and cut the strap with it and then pulled the pump out, some people pull on the housing till the slot on the housing breaks. i also notched the plastic panel to let the hoses in the trunk. heres the pump i pulled out
