Originally Posted by jbh
So how much camber do you run with the washers? Any negative effect on daily street driving?
Yes the 245 square setup may be a little overboard but after today I will take loose over tight. I assume your running 245/275 setup?
Thanks.
I'm running 245/275. With a washer I got to about -1.7. I may be forced to get camber plates because for the street I wouldn't want to go much more, but for autox I'd like even more.
Turn is is a lot quicker with the washers, and my outside tire wear has been reduced but not elimiated. I don't know what the long term wear is for daily street driving, as mine is a weekend car.
