Originally Posted by antennahead
Originally Posted by deemo319
I haven't seen those on their before because I didn't even think about looking for them there. And that's a great link, thank you.
I was informed by the local stealership, Fields BMW that it required four sets of them which seems like a lot.
I did a spot check of mine back when I researched the parts and saved them in my ECS future purchase folder. "If" I am recalling this correctly, it just takes the one set. I also removed a couple of mine, and they came out and re-screwed back in fine, so unless you damage/strip one that's in there now, the set is kind of a back-up should you need one or two extras. I think the dealership screwed up stating you need 4 sets.
I have some of my original bolts but would rather have a full set of new bolts to go with the new windshield frame cover, that way everything is new.
So I will order a set from ECS with the link you kindly provided.
