With the pads in place at the jack points, you need to keep from crushing them with your floor jack. I started with 4 1-1/2 pieces of hardwood 1X2s, which go into the rubber "cup" so the jack lifts them rather than crushing the cup. Then I got fancy with some phenolic adapters I found on EBay. There are some absolutely beautiful aluminum ones out there, but pricey.
