Originally Posted by StickMon
I think I figured this one out. I hadn't seen the splash screen since I first rebooted after updating the software. The splash screen is displayed for 8-10 seconds while the system boots up. The system boots as soon as you open the driver side door. You have to get your key in and turn it before the boot is complete to see the splash. I'm usually too busy stowing my coffee mug and docking my XM to get the key in that fast.
Genius!
Other than the first rebooted after updating the software, I've only seen the splash screen popped up 2x as I couldn't figured out what the problem was...that is until now. You are absolutely correct about the splash screen being displayed only about 10 seconds after system boot (after driver door open). I hardly see it because I too, do too much "fiddling" after getting in prior to starting up
