ZII "rubbing" noise
Was curious if anyone else has encountered any slight "rubbing" noise from the DUnlop ZII's. I just recently put these on and every now and then I hear a light rubbing sound from the front. Now, I also had the the alignment and camber done at the same time. The tire is 245/40 and they were ablet o get -2.3 camber.
I've looked and I can see anything that might be rubbing against it...Not loose plastic, it's not hitting the strut or fender, tire pressure is 34 first thing in the mornings. Today on teh drive home I thought maybe it might be I'm hearing the road hitting the grooves on the sides of the tread? Due to the little bit of camber, and maybe it's not something I've heard before these tires.
Random question, but just thought I'd ask.
