      11-04-2011, 01:25 PM   #13
Neverlift328
Drives: 2007 Z4 M Coupe
Originally Posted by Roffle Waffle View Post
I run 265mm RE-11s all around, its fantastic! 18x9 wheels, spaced 35 offset front, and 20 rear
I was going to run the 18x9 but I wanted the concave look. Do you think rubbing will be a huge issue with my setup?? I really wanna make sure I can run these without issue before I spend a couple grand
"The best way of making a car faster is to tighten the nut behind the wheel"
