Originally Posted by sknobs
Originally Posted by fcar807
if you got original key already you just need to get them cut and you should be able to pair both keys yourself and for engine start,
I managed to get one done as a spare not upgrade as you like, but followed this guide worked perfect.
https://store.bimmernav.com/blogs/ho...5-e46-x3-z4-z8
Did you get your key from BMW? All the locksmiths that I asked said you need to use the AK90+ to program any new cut key. I thought that process only worked if you get the key cut from BMW with your VIN programmed into it.
No went to a small local locksmith, he kept saying same thing tell him you only want it for opening the doors in case you lock your good one out is what I said and he cut it. Don't use timpsons they just say needs a programmer, I just tried that key and it's not starting the car weird it worked before and a week after wonder if it's a cheap key and somehow lost its pairing
