      02-05-2023, 08:34 AM   #6
grannyknot
grannyknot's Avatar
953
Drives: 2008 Z4M coupe
Originally Posted by racerbruce View Post
Thank you - great detail and keep us posted if/when you are able to achieve via OEM wiring.
I wasn't able to use the OEM wiring for any of the gauges but adding the the sensors for water temp and oil pressure wasn't bad at all.
The water temp sensor was installed in the coolant drain plug on the block under the header and the oil pressure sensor was installed on the side of the oil filter housing.
I had to fart around with the fittings to get the right combination but it works well now.
I used the push button gauge from these guys, https://blackstarmanufacture.com/produkt/multigauge/
Now I can see what the fluids are doing before the TOO LATE warning light flashes.
2008 E86 M coupe
racerbruce3854.50
3002 tii2293.00
