Originally Posted by SDCoupe
Finally got my wheels and tires mounted. Apex 18 inch Arc-8 anthracite 9.5 inch rear rim with 275/35 and 245/40 on 8.5 inch front. No rubbing. Stock suspension. This size preserves the original rolling diameter.
I have this exact setup, using Michelin Pilot Sport 4S tires. At full lock (left or right), I get slight rubbing on the front fender liners. When turning right, the outside edge of the tire touches the driver side fender liner, and vice-versa. The tires are touching the little access panel cover.
These are brand new fender liners and seem properly installed. Is this normal? Didn't think 245/40/R18 on an 8.5 inch front ARC-8 wheel would be pushing the limit here. It only happens at or near full lock, but still...
