Originally Posted by Cybmx
Wow that kinda killed my plan for getting that clutch flywheel kit. Any other options? I was also considering the clutch flywheel combo from rogue engineering, anyone tried those?
Don't do it , the stock is more than good enough even for track use, I've had 0 problems with mine, plus there was zero evidence of slippage on my stock one when I "upgraded it" . The stress on a supercharged motor crank is already extreme taking away one of the major vibration dampers (the dual mass flywheel) is a bad idea which i proved. FYI the vibration was so bad it actually worked my belts off my crank pulley in 300 street miles . My two cents
George
