Originally Posted by Daemonblitz
So stock in Z4M is:
F 18 x 8 ET 42 225/45
R 18 x 9 ET 30 255/40
I can get a great deal on a set of e9x M3 rims Style 220M, they are the following specs (with these size tires already mounted on them):
F 19 x 8.5 ET 29 245/35
R 19 x 9.5 ET 23 265/35
Online Calculators showing:
Up front rim would stick out 19mm more.
In the back rim would stick out 13mm more.
I don't think the rears would be a problem but i am worried about the fronts sticking out too much and rubbing. Currently i'm on bone stock suspension and camber.
Am i going to rub or is it a safe set up ? anyone else running these specs for their 19s ?
Did you get this working in the end? Or has anybody else confirmed whether it works or not?
