Originally Posted by seank
You are understanding correctly, although I have never seen even a stock car that doesn't have any pre-load. It is possible though. And a stock car isn't corner balanced, which is unnecessary unless you are tracking the car.
A correct corner balance is with you in the car or substituted weight, so it will be different for every car since we don't all weigh the same.
So if I get this correct, you'll want to corner balance the car so that while you're sitting in it you avoid undistributed pre-load on the sway bars.
(thinking that while you sit, you'll preload the bar on the driverside if you don't corner balance correctly)
Yes?
