Originally Posted by 3002 tii
Those wheel specs are fine but the 285 tire is the issue, and frankly overkill. Stepping down to 275 or 265 would work.
Re spacer, is that based on a wheel template or have you actually tried mounting the wheel? The issue is the convex spokes so I can see how there might be a slight clearance over the calipers. But I’d just run a spacer and run a 245 tire.
Thanks for the post, sorry I missed this--like 2 months ago...
The reasoning for the 285 is that it is smaller in diameter than the available 275 tires.
The real answer is for me to quit being cheap and buy a proper set of squared up wheels all around.
