      11-24-2012, 08:08 PM   #4
beta
Drives: 2006 M Roadster
You're in luck, typed this up for a friend. This is all the hardware involved.
Copper Collar Nut x 18 11 72 1 437 202
Header to the engine, 3 per pipe hence 18
Exhaust Manifold Gasket x 6 11 62 7 830 667
Gasket between header and engine
Exhaust Stud x 18 07 12 9 900 298
Studs on the engine for the headers
Exhaust Seal Ring x 2 11 62 7 830 668
Ring between headers and cats
Hex Nut (M10) x 4 18 30 1 317 898
Copper nuts between headers and cats
Exhaust Gasket x 2 18 30 7 830 674
Gasket between cats and x-pipe
Hex Nut (M8) x 6 11 62 1 744 323
Nut between cats and x-pipe
Originally Posted by usaz4mcr8cr View Post
also, will I need to wrap the O2 sensor wires to protect the from the heat after I unfold them? If so, what kind?
I used a cloth tape, check my mod thread in my sig. If I were to do it again I'd check CRFine's thread and just make extensions. He has pictures of them in this post. You only need 10cm or so.
If there are any additional parts that I may need please chime in.
You will need clips to fix the O2 wiring to the heat shield. I don't have a part number but check my mod thread for pictures of them.
