      01-03-2021, 05:57 PM   #185
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
Hello all,
I'm trying to test the DISA valves that came with the 3 stage intake I bought a while back. Would the DISA part number matter? The ones that came in the intake (11617560538, 11617560537) are a different number than the ones listed for a 2007 Z4 3.0Si. I have had the Si tune put on my ECU but having problems testing the DISA valves before installing the intake on the car. I tried my Foxwell 14020SCH but it stops working when I try to activate the DISAs. I have Inpa but it has scripting errors every time I use it. So I'm not sure if its even working or worse may cause a problem from the errors. I have BMW Scanner 1.4 but not sure if it can do anything like this. Ugh!?!?!?!?!
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
