Originally Posted by TestShoot
In the past with a Volvo I had success with the AC DIY kit.
As for venting, they got ahead of themselves before I approved the work while my buddy was checking to see if he could fit me in. I was told with these newer kits it may take a bit to get working properly and that 15 minutes of run time is not enough.
I'm not sure I follow you, but regardless, a overcharged system will not run as cold a system filled with the proper amount of freon. More is not better. Overcharging can even damage the compressor. What temperature is coming out of the vents?
