Car was serviced today.
When I took the car in today, it wasn't making the noise as it was before, but then it's the A/C, and it's now 20F outside.
The tech did say that in the past, they've found similarly (written up, anyway) noises to be due to a low refrigerant level. They did find the system fill down to 8 oz, when the spec is 21 oz.
System was evac'd and refilled. We'll have to see if that addresses the issue or not.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
