      11-12-2012, 07:15 PM   #11
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Originally Posted by jrich4411 View Post
Ok - next question. I've pretty much decided on the ARC-8s from Apex. Do I stick with stock wheel widths - 8.5" front & 9.5" rear - or do I step up to 9" front & 10" rear. I will be running stock tire sizes at least until my current tires are worn out. I do not track - but I do "occasionally" run a little spirited when the occasion presents itself (onramps, deserted back roads, etc).
If I do move up to wider wheels - 9" front offset 42 mm & 10" rear 25 mm offset - do I need to worry about spacers? and what size tires can I put on these wheels without worrying about rubbing?
I know a lot of you guys have already answered these issues on your own ///Ms.
Thanks!
I think the stock size is 8" front and 9" rear. Correct?
