Originally Posted by exdos
I suspect that you also had a lot of toe-in at the front. Try a touch of toe-out and the car will become very "pointy". Why do you need so much static camber?
Like seank mentioned, it depends of your skill level and car setup. I've been instructing since 2008.
I have no camber wear running that much static camber. With -3.2 f, I had camber wear on the outside shoulder ...
I have 650f/750r spring rate with KW Clubsport, GC hollow sway bars with adjustable links, Pirelli Dry Hard slicks, APR wing and splitter.
I have more toe-out than I usually had on my E46 M3. I don't remember exactly (will need to check) but I think I have 1/16'' total toe out.
Things I suspect:
-rake/splitter angle under acceleration
-APR wing was not set properly, give too much downforce and drag also.
-front swaybar adjust too stiff, rear swaybar adjust too soft
-too much camber in the rear
