      11-20-2015, 04:34 PM   #25
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
Originally Posted by F360C View Post
I agree with dc-wright on this... run at least a 255 with that 275 rear. These cars need way more tire up front for autox. 255 is good, 265 even better and square 275 is where the money is at. With that said I also found the 255/35/18 fit better then the 245 due to the height of the sidewall. Our cars can take more tire up front then most people think with out rubbing. The limiting factor I find with the front tire is the diameter of the tire.
Last autox of the season coming up for me this weekend!
What about when you put -2.5 camber? Will the 255 up front rub on the spring or spring perch?
