Originally Posted by BabygirlsZ4
Old thread... new member...
Buttons work. Blinks red until locked in up or down position.. Micro switch works.. Motor runs.. Red tab does nothing in or out.. We can still move it manually either way with ease.. top just wont move on it's own once unlocked... We bought a motor hoping it was just weak but.. Not so sure now.
It could be a leak. If the motor runs but nothing happens, it is probably low on hydraulic fluid (or empty). Also, it should not be easy to move manually with the bypass tab in the normal, non-bypass (ie. "in") position. This too points to a leak.
I was able to remove the top from the car in just over an hour the other day. This is probably the only way for you to diagnose the issue.
