      11-03-2007, 10:12 AM   #7
Dirfm01
Drives: Saphire Black 2006 Z4M Coupe
Guess I will go along with it also...2006 Z4M Sapphire Black Coupe...no pics at this moment...Car came with everything except for the navigation system.
On The Car:
Dinan 3.91 LSD.
Dinan carbon fiber and aluminum front strut brace with stage 2 aluminum front strut tower braces.
Dinan 19 inch monoblock rims (19x9 with 3mm spacers front, 19x10 with 5mm spacers rear).
Dinan high flow throttle bodies.
Dinan rear trailing arm monoball kit.
Brembo red BBK (6 piston front, 4 piston read, cross drilled rotors, stainless steel brake lines).
H&R sport springs (1 inch drop all around).
ACS aluminum pedal set, handbrake, and shift knob.
Stealth XM radio install.
Standard antennae exchanged for micro antennae.
Custom/Stealth K40 bluetooth radar detector and laser diffuser.
10% Huper Optik tinting on all windows but the windshield.
Full CTD Germany aluminum interior accents.
CDV removed.
UCC motorwerks clutch stop.
UUC Motorwerks chromoly adjustable rear control arms.
UUC motorwerks EVO3 short shifter.
J&B Performance Clutch and ultralight flywheel.
One peice machined brushed aluminum oil cap.
Rogue Engineering reinforced rear shock mount system.
Rogue Engineering performance engine mounts.
Rogue Engineering reinforced transmission mounts.
CG lock 3 point harness for both driver and passenger seating.
VentureShield coating on all forward facing exterior body components.
Full xenon interior lighting upgrade (Set of 11 lights).
Shaved side turn indicators.
Driver and passenger OEM under seat European first aid boxes.
OEM BMW alarm system (with clown nose activation).
OEM BMW secondary drivers side floor cargo net.
OEM BMW Z4M auxiliary input (ashtray setup, not the panel exchange).
OEM BMW rubber floor mats.
OEM BMW shoulder strap adjusters (set or 4).
On Order:
OEM European headers
Supersprint flow cats
Think that has it covered.
