I'm running a set of APEX 18x9.5 et35 (square setup) I purchased from VAC with 245/40/18 RS-3 Hankook tires. I believe this set up would work even with 265/35/18 tires.
http://store.vacmotorsports.com/vac-...els-p2328.aspx
With this package you have to run with negative camber, I have a set of Vorslag camber plates (-2.5) with AST coilovers dropped about 1.5 inches with zero clearance or rubbing issues. If I was tracking the car, I would have gone with the 265/35 series tire, but since it is daily driver, the 245/40 is sufficient and still "wanders" with road variations.
I did add a 15mm spacer to the rears to bring them out to match the fronts. Made a difference in the looks of the car.
