      05-31-2013, 03:08 PM   #318
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Originally Posted by DanFromTucson View Post
Installing these does require removing the aluminum reinforcement plate right?
I assume you talking about engine mount brackets. No, you just loosen the engine mount bracket bolts. The allows you to wiggle the engine mount out.
Originally Posted by beta View Post
Do the engine mounts before the tranny mounts. Transmission mounts make a tiny difference, engine mounts transform the car. Just my 2c.
+1
I changed my tranny mount first but this caused my engine mount bracket bolt cracked. You can if you know your bolts are replaced. If it hasn't been replace, you can replace it when you install engine mount.
