The spec for negative camber is pretty aggressive for the Z4. The wider the tires, the more you see it. I think is does put more pressure on the RTAB (rear trailing arm bushings. If you do not know for sure those have been changed, it is time. The inside edge of the tire will wear very fast. keep an eye on it.
