Originally Posted by tarheel91
Is your sidewall ratio still 40 up front, 35 rear?
Also, as v3.0si, what's the offset? The last owner says mine is at stock offset which I assume is 47 front 50 rear. I haven't tried to confirm this, though. I can see how 9's would rub in the front with an offset in the 30s.
I'll have to record the offsets again when I get the wheels pulled again....as I can't recall.
The tires are 30 and 35 series sidewalls.
