what wing did you go for and size?
I would say 67 to 71" wing, with big splitter, with stiffer spring rates to compensate, upgrade front sway bar and put in stiffest settings, strut bar, and OEM rear bar.
that will most likely keep your car more neutral.
Alingments, make sure you get more caster over camber.....get as much caster as you can.
