Originally Posted by dc_wright
If you have your heart set on R-Comps you might have to look at going with 245/40 x 18 on all 4 corners. You're only looking at 0.3" diameter decrease in the rear going down from the stock 255 and the increase in grip from the R-Comps will more than compensate for losing 10mm in tread width. In the front the diameter between 225/45 x 18 and 245/40 x 18 is almost identical and the 245's should fit with no issues.
Thanks! Any recommendations on brand and model of tire to go with?
