1. Unmatched set of front & rear tires
2. Fuzion tires look undersized on the rims which may mean that the rims are not 8.5" but instead probably wider (compare them with the Goodyears... wider tires on the same sized rim should make them look more oversized and not undersized).
3. Too much curb rash for show. Unless you're planning to use them as winter wheels, the blemishes detract from the overall. And the cost of refurbing... I'd rather get a new set.
4. This wheel looks like there's a crack in the bottom right corner.
http://i254.photobucket.com/albums/h...L/P1000833.jpg
In this case (IMHO) the tires are useless to the deal since I'd end up remounting brand-matched tires. I'd offer no more than $450 for the set and $300 for wheels only. And that's ONLY if none of the wheels are cracked/bent. AND come with centercaps.
