Originally Posted by minmat11
Thank you! I found them. My only question is what size do I need to use for the bigger lens? I know it's 70mm for the smaller one. I can't thank you enough for the info!
Yousefnjr said the factory size for the inner ring is about 2.75" (70mm) and the outer is slightly larger at 3" (~76mm). He ordered a set of 70mm and 2 sets of 80mm to experiment, so you might want to PM him to see if he's gotten around to the project yet. Another member Pungo might also have some info since he's done the mod himself, although I'm not sure if he used CCFL's or LED's.
