      05-04-2023, 10:44 AM   #3
1z2z
Drives: BMW Z4 (E85)
Made a sling to lift the engine
I used a 2x4, scissor jack and a ratchet strap to lift the driver's side of the engine. Used the 2x4 as a bridge between the strut tower brace and the core support. Placed the scissor jack on top of the 2x4. Looped the ratchet strap under the engine bracket that attached to the motor mount and over the top of the scissor jack. Used the scissor jack to do the lifting. Had to raise the motor about 4 inches on the driver's side to get the water pump out.
