Originally Posted by dbarton62
Yep
European power values but M54 came in 3 displacements
Engine Displacement Power Torque Redline Year Stroke Bore Compression
M54B22 2,171 cc (132 cu in) 125 kW (168 hp) @ 6100 rpm 210 Nm (155 lbft) @ 3500 6500 2000 72.0 mm (2.83 in) 80 mm (3.1 in) 10.8:1
M54B25 2,494 cc (152 cu in) 135 kW (181 hp) @ 6000 rpm 237 Nm (175 lbft) @ 3500 6500 2000 75.0 mm (2.95 in) 84 mm (3.3 in) 10.5:1
M54B30 2,979 cc (182 cu in) 170 kW (228 hp) @ 5900 rpm 300 Nm (221 lbft) @ 3500 6500 2000 89.6 mm (3.53 in) 84 mm (3.3 in) 10.2:1
S54B32 3,246 cc (198 cu in) 256 kW (343 hp) @ 7900 rpm 365 Nm (269 lbft) @ 4900 8000 2001 91.0 mm (3.58 in) 87 mm (3.4 in) 11.5:1
Did you get the GEN3 M54B25/B30 performance headers for $276 or the SS M54B25/B30 V1 performance headers?
