07-07-2014, 04:36 PM
#6
Yep
European power values but M54 came in 3 displacements
Engine Displacement Power Torque Redline Year Stroke Bore Compression
M54B22 2,171 cc (132 cu in) 125 kW (168 hp) @ 6100 rpm 210 N·m (155 lb·ft) @ 3500 6500 2000 72.0 mm (2.83 in) 80 mm (3.1 in) 10.8:1
M54B25 2,494 cc (152 cu in) 135 kW (181 hp) @ 6000 rpm 237 N·m (175 lb·ft) @ 3500 6500 2000 75.0 mm (2.95 in) 84 mm (3.3 in) 10.5:1
M54B30 2,979 cc (182 cu in) 170 kW (228 hp) @ 5900 rpm 300 N·m (221 lb·ft) @ 3500 6500 2000 89.6 mm (3.53 in) 84 mm (3.3 in) 10.2:1
S54B32 3,246 cc (198 cu in) 256 kW (343 hp) @ 7900 rpm 365 N·m (269 lb·ft) @ 4900 8000 2001 91.0 mm (3.58 in) 87 mm (3.4 in) 11.5:1
