Originally Posted by 964junkie
Hi all, I just got a z4 m coupe and I'm looking to hard wire my V1. I previously had an e46 330i which had the V1 hard wired to a green/blue wire near the rear view mirror, which allowed the V1 to turn on when the key was in position 2. Does your V1 turn on when the key is in position 2 with the V1 hard wired to the white/purple wire?? The ground wire in my 330i went to the sunroof screw, and the m coupe does not have a sunroof. Where did you attach the ground wire? Thanks!
There is a screw perfect for the job up in there. Just pull down the map light assembly and it is right in front of you.
