Originally Posted by beta
pickeyeater334's ebay clutch stop.
There's a thread here about it. To install it just put the nut on the bolt, then replace your existing plastic clutch stop with this one. To adjust: turn your key in the ignition, then press the clutch and listen for a relay to click. You want your clutch stop adjusted to just past the relay click point.
Easy and inexpensive mod and makes shifts easier and more predictable.
are you talking about turning the key in the ignition all the way to the start position?
