Originally Posted by tambyz4
Just to add to this thread, I had a similar problem with my 07. Couldn't figure it out, until I read a ton, then started playing around with the rear shelf. It wasn't the shelf or the sensor, turned out the red ring that pulls to release the hydraulics was partially pulled out. I put it completely in and everything started working.
Just incase another person has the same issue. Something to check.
JT
Thank you for taking the time for the post. I just "fixed" my wife's Z4 top issue, thanks to your post.
Took a lot of searching to find such a simple solution. But it worked and I am thankful.
Cheers,
Ron
