Originally Posted by Clearancediver
Does everyone understand that the oil sold as a "litre" bottle of oil actually only contains 954 ml of oil... (At least here in Canada... and likely the same in USA as our oil comes from same manufacturer). The 46 ml of oil missing from the bottle times 7 gives 320 ml of oil. So filling it with 7"litre" bottles means that you actually filled it with 6.68 liters of oil. Deduct the slight amount remaining in the bottle and the amount absorbed by filter paper...... Well you get the idea...
If that's the case, then you Canadians must be doing some funny math
Everywhere else, 1 "litre" of oil is exactly 1000 mL. The confusion is that BMW sells oil in both Liters and Quarts. The 5W30 oil that is used in most BMW comes in 1 Quart bottle = 946mL as pictured. The 10W60 used in ///M engines comes in 1 Liter bottle = 1.05 Quarts, also pictured here. Oil fill for our S54 engine calls for 5.5L, which should be approx. 5.8qt...so most people would just round up to 6qt and call it the day. But since the 10W60 comes in Liter, these mechanics are actually pouring 6L (approx. 6.34qt), which is a good 0.5 liter overfilled.
