      07-01-2013, 12:15 PM   #2
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
Originally Posted by raptor View Post
Does anyone have experience with both of these cars at the track? Are there any big pros/cons for either car that I should know about?
I've driven both and my assessment is that the M3 provides a "simpler" and easier-to-approach on-track experience. The Z4M is a more "complex" and, thus, more exciting experience.
The Z4M obviously has the same power dynamics. It weights a bit less, sure, but you don't really notice that. What you do notice is the shorter wheelbase... the car rotates very easily and the seating position exaggerates the sensation. You can get the car into turns with minimal effort and kick the back out around the apex without any drama. Because you're sitting on the rear axle, I feel you have more awareness of the car's slip angle. It's a more "twitchy" experience but, like I've said, figure it out and you'll be rewarded. Better steering rack/ratio... amazing steering wheel... the Z4M has a lot going for it!
Will I be able to fit my 265/35/18 RS3s under the front of the Z4M?
Depending on negative camber specs, absolutely. Stock... no way.
Now go buy my car... http://www.zpost.com/forums/showthread.php?t=807212
...wait a second, was it you I was talking to at the TrackDaze event?!
|www.onehotlap.com|Real People|Real Cars|
